remote my SQl call from a microcontroler
Amalinda
Banned
Full Member level 1
is there any possibility using a microcontroler such as ARM Cortex-M or MSp430 or PIC to add data to my remote database located at hostgator? (perform a remote DB call)
please note I do not want to use RTOS or any operating system. I strictly want to use C.
let me know if there is at least a conceptual way of doing it.
thanks for all replies.
if your microcontroler has a network connection (e.g. ethernet or wireless) or a TCP/IP enabled modem you could use TCP protocols to access the database
hey Horace1,
thanks for the answer.
yes, my development board (https://www.ti.com/tool/ek-tm4c1294xl) has ethernet. It also has a Wifi sheild(CC300 Wifi cape by TI). Assuming I already have an internet connection through ethernet could you please give me a little guidance to write the code? I only require a little guidance for the SQL part.
my DB ip lets say 124.43.29.78 and DB username USER password : PASSWORD.
DB name : DBNAME and table, DBTABLE.
//lets say internet is given by the following function
ethernet_activate ();
Could you please tell me how I should approach it? where can I find the libraries?
I found this great article. (its one article altogether)
http://drcharlesbell.blogspot.com/2013/04/introducing-mysql-connectorarduino_6.html
library files : https://launchpad.net/mysql-arduino
but I dont know how I can fit these auduino libraries to any TI ARM Cortex-M or a any PIC or a MSP430G253. I cannot use Auduino since its not allowed.
The stackoverflow one is good! thanks.
its simply calling a URL havign all variables in the URL itself.
but my question is
1. How do we make sure the data reached the server with o errors?
2. How to we make sure that this method is secure? may be by usign https?
i think anyhow, there is no need to use remote DB updates over a micro after seeing this method. one should be able to encrypt the data and send.
thanks again!
