JitterJaw
Newbie level 6
I'm designing a remote controlled switch for my water heater and I am bothered by the following questions:
1. Should the switch be DPST, or can I just switch the phase line (dangerous?) ? can I do it by using 2 SPST with the same control signal instead of a DPST?
2. Can anyone recommend a relay for switching ~2.5K Watts water heater running on 220V AC? Should I look for something specific in the datasheet of the relay?
3. There seems to be a big range of prices on relays, is there any reason to invest in a brand name, or ordering one from dx will also get the job done?
4. Is there any reason to prefer a TRIAC over a relay for this kind of project, keeping in mind that the times it will be switched is about twice a day.
5. Is zero-crossing relevant for this low number of switching, or is it just a precaution used on high switching frequency. Is an opto-isolator obligatory?
Thanks in advance
Thanks in advance
