May 9, 2004 #1 D david90 Advanced Member level 1 Joined May 5, 2004 Messages 423 Helped 9 Reputation 18 Reaction score 4 Trophy points 1,298 Activity points 3,611 what kind of relay can be use to accept the "HIGH" 5v output of a D FF to drive another 12v ~5 amps device? Also, what is the best way to make a clock for my D FF that pulsate every 2 seconds?
May 10, 2004 #2 SphinX Advanced Member level 3 Joined Jan 25, 2002 Messages 822 Helped 58 Reputation 116 Reaction score 29 Trophy points 1,308 Location EGYPT Activity points 7,045 Hi, You can use transistor as switch which switch on or off a relay. The TTL o/p go to the base of the transistor. Bye
May 10, 2004 #3 D david90 Advanced Member level 1 Joined May 5, 2004 Messages 423 Helped 9 Reputation 18 Reaction score 4 Trophy points 1,298 Activity points 3,611 How do you detect flyback when a motor is stuck?
May 13, 2004 #4 C C8H10N4O2 Newbie level 6 Joined May 13, 2004 Messages 13 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 116 Try a solid state relay such as Fairchild HSR312.
May 14, 2004 #5 C cngroup Newbie level 3 Joined Mar 30, 2004 Messages 4 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 36 You can put buffers or inverters in between FF and the relay. They can be paralleled to sink/source current enough to drive the relay.
