[SOLVED] Relay operate Using Parallel Port of CPU
nick703
Advanced Member level 1
surat
hello friends i want to operate Relay using parallel port of CPU .
I have a Leone DC12 V Relay , one 1N4007 Diode , one BC547 transistor and 470 ohm Resistor . so is that possible to operate relay using Parallel port . and i have also Lalim Parallel Port EXE . so any circuit is diagram may my help !!!
This is a nice portuguese parallel port tutorial
Search for Circuito-3
Use google to translate!!!
Or google + parallel port relay circuit
Isolated circuit:
thanks nagkiller . now i want to know is that possible to power up relay 12v take in the CPU parallel port or any other device of CPU becuse no more power supply like S.M.P.S .
Parallel port dont have power... you need external power, like above image!!!
