[PIC] relay control by mcu
Muhammad.Saad
Newbie level 6
Islamabad, Pakistan
Hi
I am new to mcu. I want to make a project for controlling two leds. I am using PCW (Pic c compiler)Please help me to correct my code to on/off relay through potentiometer reading(0 to 5v). I need to on the relay when voltage is under 1.5v and above 4.5v. here is my circuit.I need to operate rely for under and over voltage limitations.
lower limit is 1.5v
upper limit is 4.5 v.
Here is code
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
#include <main.h>
 #fuses NOWDT
 #fuses NOLvP
 #fuses HS
 #fuses NODEBUG
 #include<stdio.h>
 #include<STDLIB.H>
 #use delay(clock=11059200)
 #DEFINE relay_on 1
 #define relay_off 0
 #fuses HS,WDT
 unsigned int8 relay,adcvalue, LOWERLIMIT, UPPERLIMIT;
 void main(void)
 setup_adc( ADC_CLOCK_INTERNAL);
 setup_adc_ports( ALL_ANALOG );
 ( input(PIN_A0));
 set_adc_channel(0);
relay = read_adc();
 LOWERLIMIT = (5*relay*100/1023);
 UPPERLIMIT = (5*relay*100/1023);
if (LOWERLIMIT < 2)
 output_low(PIN_C0);
 Else
 output_high(PIN_C0);
 if (UPPERLIMIT <= 4)
 else
 output_low(PIN_C0);
Looking forward for reply
Looking for help
1) In this statement:" LOWERLIMIT = (5*relay*100/1023)" why are you multiplying by 100? I am assuming you are trying to convert the ADC reading to voltage (which is not really necessary to begin with), but that's not what you're doing (unless the ADC range is 0 to 500 volts). And then you've assigned UPPERLIMIT which is EXACTLY THE SAME THING as LOWERLIMT!!
2) What you really want is something like:
 (not real C code)
if( (relay< lowlim) or (relay>hilim) )then
RCO=1;
else
RCO=0;
3) I assume the top of your relay is tied to some voltage?
4) Put a diode across that relay, or you'll damage something...
if (LOWERLIMIT < 2)
output_low(PIN_C0);
Else
else
output_low(PIN_C0);
change to this
relay = read_adc();
relay = relay*(5/1023);
if (relay < 1.5)
else if (relay > 4.5)
else
output_low(PIN_C0);
HTML:
Hi baryy
the problem is relay in continuously on the code is not working properly. If you have time i am sending proteus file please correct the code and simulate on proteus. I will be very thankful to you.
thanks alot
HTML:
hi lockman_akim
thanks for help but it is still not working
  • Lab 03.rar
  • Lab 03.rar
Is this a real circuit or a simulation you are having a problem with? It's totally unclear.
I am using pic c compiler for coding and it is a simulation on proteus. i just want to switch on the relay when voltage is under 1.5volts and above 4.5 volts.
1.5 is the lower limit
4.5 is the upper limit.
when ever voltage cross the limit the led should on.
thanks
Try this code.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
#include <main.h>
#include<stdio.h>
#include<STDLIB.H>
#fuses HS, NOWDT, NOLVP, NODEBUG
#define RELAY PIN_C0
#define LOWER_LIMIT 1.5
#define UPPER_LIMIT 4.5
float adcValue = 0.0, oldvalue = 0.0;
void main(void)
    setup_adc(ADC_CLOCK_INTERNAL);
    setup_adc_ports(AN0);
    set_adc_channel(0);
    while(1)
        adcvalue = ((read_adc() * 5.0) / 1023.0);
        if(oldvalue != adcValue)
            if((adcValue < LOWERLIMIT) || (adcValue > UPPER_LIMIT))
                output_high(RELAY);
            else
                output_low(RELAY);
                        oldValue = adcValue;
You should say that you want to turn ON the Relay when voltage is less than 1.5 V or greater than 4.5 V. It can't be < 1.5 V and > 4.5 V at the same time.
Your circuit is wrong. The Ceramic Capacitors used in the Crystal circuit should be 33 pF each and the diode in relay circuit should be connected across the relay coil terminals.
