Relay Coil 270R 6v ,SIL ,4 PIN
abs11
Newbie level 3
Newbie level 3
Wigan,UK
Hey everyone. im using circuit Wizard to simulate a circuit and within the circuit ive used Relay coil 270R, model 6v, type SIL, and its 4 pin. I could not find a matching datasheet anywhere.
can I used any Reed Relay SIL??
thank you
The coil voltage has to be selected according to the available supply voltage. Standard voltages for reed relais are 3V, 5V, 12V, 24 V. A 5V coil has e.g. a maximum pull-in voltage of 3.5V at 20°C, rising to 4.3V at 85°C. The maximum applicable coil voltage is limited by the power dissipation, it's e.g. 7.5V for 5V nominal voltage. In so far, a 5V relay will usually fit.
SIL in not the relay type or company name, it is Single In Line pin arrangement because all 4 pins are in one straight line.
Alex
