adnan012
Advanced Member level 1
hi,
For the design of a buck converter is it necessary to derive its transfer function equation for designing PI controller.
Is there any relationship between transfer function an PI (feed back loop)?
Suppose that there is an arbitrary buck with specifications
vin 20 v
vout 5 v
Rl 10ohm
If i want to implement the feed back loop by using micro-controller using ADC etc. Here i need to sample output voltage via potentiometer and then set pwm.
At this point do i need to know pole and zeros , crossover frequency , phase margin etc?
vin 20 v
vout 5 v
Rl 10ohm
