Murugesh_89
Full Member level 5
- Joined
- Nov 23, 2012
- Messages
- 266
- Helped
- 7
- Reputation
- 12
- Reaction score
- 6
- Trophy points
- 1,298
- Location
- India
- Activity points
- 3,267
I am using a 7808 smd type make of ST. The circuit draws 450 mA from the 7808. I gave 24V as input to the regulator ic.
I have also provided the heating dissipating area around its ground pad. But the IC is overheating and i cant able to place my finger over it for more than a half second.
As a result the output voltage reduces to 4 or 5 V after some 2 minutes from power ON. Then if i switch OFF and then ON the power supply it will be ok for next 2 minutes.
How do i get out of this issue?
Thanks,
Murugesh
Thanks,
Murugesh
