Regarding WiFi Ethernet PHY Module
sakibnaz
Full Member level 3
Full Member level 3
Regarding WiFi Module
Hi all.
I am looking for a WiFi Module but my requirements are quite different.
- SMT based
- Internal Chip Antenna
- WiFi Client / AP / Router Mode
- Ethernet PHY Interface
- Supports AT Command through UART
- Internal Web Server
- definitely not too expensive cost
I found some module but not fulfilling all the needs. Example HI-LINK HLK-RM04. Its good. But its not SMT :(.
If anyone knows a good Module which can fulfill my needs, please advise.
Regards.
Re: Regarding WiFi Module
ROVING RNxxx SERIES you should check RN171
Hi.
I checked RN-171 and other RN series. They don't have Ethernet PHY.
Any other suggestions ...
Regards.
Hi
I have recently come across WIFI module by DIGI in same footprint as Zigbee modules. I was searching for something for my home automation project.
The advantage to me is that it can be used with Zigbee shields of Arduino. The whole setup with webserver(on Arduino) will be around ~70 USD.
Thanks
