[General] REGARDING Sim900 AND sENSORS
aravinrjn47
Newbie level 2
Newbie level 2
Hello Sir,
My project is based on sensors and SIM900 module.
We've got a SIM900(SIMCOM) module and piezo vibration sensor. We've tested the SIM900 and the sensors.. both components are working fine as given..
We did a program for the following cases
1)when the modules are turned ON, a call should be made to the given number.
2)when the sensors are vibrated an interrupt should be given and call should be made to the given number.
These are the cases.
As far as, the connections are made perfectly in between the modules and the sensors. the micro cotroller we use is TERN186. the mc is loaded with program that we have designed.
the software we use for the simulation is ParadigmC++.
During the simulation with the computer the output is obtained as expected.
But when we are practicing it without a computer we are not getting the output.
->When the modules are turned on call is repeatedly made to the given number.
->Interrupt from sensors are not making a call..
We are getting the output when simulation in the computer but we are not getting the same when we are doing actually without the computer.
can u help us with this issue ?
-the programs are compiled without errors and warning msg s. Connections are perfect.
