Jun 26, 2012 #1 Manochitra Member level 2 Joined Dec 9, 2011 Messages 47 Helped 15 Reputation 30 Reaction score 15 Trophy points 1,288 Activity points 1,585 hi.... If a design has reset pin, then it will affect input pin or output pin or both?
Jun 26, 2012 #2 S shanmugaveld Advanced Member level 4 Joined Feb 9, 2009 Messages 110 Helped 25 Reputation 50 Reaction score 17 Trophy points 1,298 Location Bangalore Activity points 1,774 Reset pins are used to put all your registers, FSM states into known state. Code: if (reset == 1'b0) a <= 1'b0; else a <= b; a - output; b as input.when reset is applied a will be assigned to 0. a will not vary wrt b until reset is removed.
