Hello to all,
I am interfacing IO expander ic MCP-23017 with dsPIC30F4011 Controller using I2C protocol. while writing code in c for that, there are more than one IOCON.BANK to be selected. I don't know how to select that register, bcoz all IOCON.BANK have same register configuration values. Please kindly suggest me if anybody has an idea about this......
it just selects the order (of the address) of the registers.
* with IOCON.BANK = 1: Addr 0x00 to 0x0A are for channel A, while Addr 0x10 to 0x1A are for channel B (address bit 4 selects channel A or B)
* with IOCON.BANK = 0: the channels are alternating: A, B, A, B ... (address bit 0 selects channel A or B)
That´s all.
--> Select the register order you find the most convenient for your code.
Hello,
But sir the point is, how to select the bank from IOCON.BANK = 1 and IOCON.BANK = 0 in program? how does dsPIC30F controller come to know about specific IOCON.BANK ? the thing you just mentioned in above thread, i already about it. the problem is the choosing of specific IOCON.BANK in code.......kindly suggest solution please....
Hello,
In section 1.6.6, it is mentioned all the steps, but how would controller know about BANK? if i simply write BANK = 1; in MPLab, is it going to work in that way? how would controller detect that BANK register?
it is almost standard I2C protocol: Device_address, Register_address, Data.
---> datasheet Fig. 1-1, Fig. 1-4.
Repeatedly I recommended to read the datasheet. The complete datasheet.
It makes no sense, that I read the datasheet for you and post each information here...
