vintujose
Hi ,
In communication system you find that coding is followed by Modulation . Following this if i try to use the manchester coded wave to PPM modulator . You find that the modulator converts the manchester code d wave back to the normal ones and zeroes before modulation . This makes the manchester coding insignificant . I want to know if manchester coding is a form of Modulation or is there anythig wrong with my logic here .Or are we not suppose to use manchester coding before Pulse position Modulation.
with regards
Vintu
with regards
Vintu
