hi
I wanna design "asynchronous" binary 8bit counter & 6 bit counter.8 bit counter will reset after 240(in hex-F0) & 6 bit counter will reset 40 bytes(28in hex).Can any1 plz give me VHDL code for it.it's very urgent.
try this code I'm not sure but it is some thing like that if he don't work tell me I will send you mine,
you can change the palce of the ce and clock to get asynchrone or synchone ce.
process ( clock, ce, reset)
begin
if reset ='1' then
counter <= 0;
elsif clock'event and clock ='1' then
if ce ='1' then
counter <= counter +1
end if;
end if;
count_out <= count;
end processs;
Your above code is not clear when the counter reaches its maximum value and reset.
As per Shraddhas' requirement, counter must be reset after max. value reaches.
By using this async counter, you can increase your count value upto max. values reach, then make it '0'. Insert a if condition after the counter assignment.
hi mmoctar
can you plz send me vhdl code for the synchronous binary 8bit counter & 6 bit counter.8 bit counter will reset after 240(in hex-F0) & 6 bit counter will reset 40 bytes(28in hex)
regrads
shraddha
