Hi, I am designing a textile antenna, for this purpose i need to define a Shieldit Fabric conducinng material with surface resistivity of 0.01 ohm meter and conductivity of 100 S/m. help me in defining this material in HFSS.
Hi, I hope this note helps you. After you draw your object in HFSS right click on the object and select Assign Material. In the opened window click on Add Material and you can define material with the desired properties in there.
