micromet
Newbie level 1
I am working on a soil sensor to measure moisture, the dc output signal decreases as moisture increases. For example, wet soil = 1400mV and dry soil= 2400mV, all running on a 3.3V micro-controller
https://wiki.dfrobot.com/Capacitive_Soil_Moisture_Sensor_SKU_SEN0193
I would like to transform the output so voltage increase as moisture increased.
Currently I just do this in my microcontroller with software.
But I was wondering if I could use a differential amplifier or other circuit to reference the output voltage to VCC instead of ground to accomplish this goal? Then a person could just read the sensor with a voltmeter and still "make sense" of the results.
If so, please suggest a part and circuit.
Thanks in advance, I'm a soil scientist trying to learn electronics.
