DAH1
Newbie level 2
Sorry if this is a very basic question - pretty new to electronics.
I am looking to but a 2-channel circuit board to switch off a pond pump when a level sensor triggers - then switch on a lamp.
I need to switch 240vac for the pump via the normally closed contacts on one relay and 12vdc to the lamp via the normally open contacts on the other relay.
Both relays will be triggered by a level sensor (essentially a reed switch). Should I fit a resistor in series with the reed switch so I am not connecting the switch across the 12vdc supply?
Thanks
David
Thanks
David
