It depends what do you want to simulate, i guess.
Actual antenna arrays are multi port devices, every port is excited
using a seperate feed. Planar arrays are generally used for scanning. Array elements are phased differently to form the beam at the desired angle. Implementations require a complicated feeding structure.
However in the litrature, you will see the term "active element pattern". This is simple measure to the antenna performance. Single antenna is excited and others are open circuited. This way, array is modeled as a one port device.
so you have two choices:
1) define a one port device
2) define a multi-port device. ie. 16 ports for a 4x4 array.
ps: Do not connect the cpw lines together; that will give you nonsense results.
