Apr 25, 2007 #1 A ashishjain_1000 Newbie level 5 Joined Apr 25, 2007 Messages 10 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,352 folded cascode amplifier what are the advantages and disadvantages of folded cascode amplifier?? Can be designed rail to rail input voltage.... low output swing... high output impedance.....what else??
Apr 25, 2007 #2 S suria3 Full Member level 5 Joined Mar 5, 2004 Messages 300 Helped 17 Reputation 34 Reaction score 5 Trophy points 1,298 Activity points 3,028 folded cascode advantages Advantage : Higher gain Disadvantage : Limited output Swing
Apr 26, 2007 #3 gingerjiang Full Member level 3 Joined Mar 1, 2006 Messages 171 Helped 17 Reputation 34 Reaction score 6 Trophy points 1,298 Activity points 2,181 cascode amplifier compared with telescopic, folded-cascoded has larger noise contribution, larger current dissipation.
Apr 26, 2007 #4 Z zizu Junior Member level 1 Joined Apr 18, 2007 Messages 19 Helped 2 Reputation 4 Reaction score 0 Trophy points 1,281 Activity points 1,373 folded cascode amp It has larger output swing than telescopic and is suitable for rail-to-rail input stage.
Apr 26, 2007 #5 Tony Teng Newbie level 3 Joined Apr 26, 2007 Messages 4 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Activity points 1,297 folded cascade amplifier advantage 1.seperate the ICMR and outputswing 2.high Gm without high power disspate 3.low noise disadvantage 1.low speed 2.high powerdisspate
Apr 26, 2007 #6 S satyasiva Full Member level 1 Joined Nov 9, 2006 Messages 98 Helped 5 Reputation 10 Reaction score 2 Trophy points 1,288 Activity points 1,714 advantages of folded cascode high gain is advantage. But it has pole at foling nodes which decreases it's speed.
Apr 26, 2007 #7 W waxtomato Member level 5 Joined Sep 1, 2004 Messages 86 Helped 13 Reputation 26 Reaction score 5 Trophy points 1,288 Activity points 354 folded cascode advantage DISAD: folded opamp has larger silicon consumption
