Recording sound to atmega16
waqaswattoo
Newbie level 3
Newbie level 3
Hy.
Can anyone help me for recording audio in atmega16?
Plz give me an idea for it.
I want to save an audio file in eeprom using atmega16 and then playback it through a speaker.
Unless you use an external EEPROM or you want to store very short audio, I don't think you'll succeed. An ATMega 16 has only 512 bytes EEPROM.
If you want do some experiments, you can follow a quick and dirty path: sample at fixed intervals the audio level at an ADC port and store raw data. You can play them later with an ADC.
Note that, even to attain a poor quality result, you need to sample each 250-300 us. Mega16 ADC is able to do so, but you roughly need 4kbyte for one second of record.
For serious results, I recommend to move to a bigger and more powerful device, such as Atmel UC3 (core AVR32), in this case you can compress the audio with a software vocoder.
n if i want to use pic microcontroller, what u will suggest to do????
if u have any program in C then kindly share it with me......
Thanks
Hi
can you use any extra IC to connect to PIC? for example ISD series ICs?
BR
I ve done this interfacing uc to a 512mb mmc on spi port. You can get pic18f452 for this
Hi
I mean extra IC for recording sound.... If you can
