Hi all,
I am need of Multimode Fibre optics cable which have to pass the wavelength 100nm to 5000nm.
Please let us know.
Regards,
V. Prakash
Vetal / India
have to pass the wavelength 100nm to 5000nm...
Do you read answers? Provided you actually have a light source emitting at vacuum UV wavelength, e.g. a plasma, you need to face the fact that even best suited lithium fluoride has a rather high absorption near 100 nm, so that it can be only used up to e.g. 1 mm optical path length.Please recommend the Fibre optics cable for this application.
I have to detect the light in one area which have high temperature like 150'c which can not keep my sensor in this heat. i am trying to
use the fibre optics cable to detect the light. the application of fibre optics is just to transmit the ligth from one end to other end. Please recommend the Fibre optics cable for this application.
