Hi all,
I am measuring the sensitivity of some radio cards, but I am unable to reach the expected sensitivity level. The sensitivity criteria is based on packet-error-rate, and I am using an RF shield box with the last 30-dB of the path loss inside the box in order to shield the card from interference. The sensitivity I'm getting is about 3 to 4 dB worse than I expect, and is consistent between samples.
I have tried adding an LNA with its own isolated power supply just before the radio card, but there is no improvement to the sensitivity. This suggests to me that the demodulator simply requires a higher SNR to demodulate than the datasheet suggests. Either that, or this is a multiplicative noise source. The radio card is hooked up to a PC via a PCIE interface, so perhaps somehow the PC's noise could be affecting the communications.
Any suggestions for how to debug this are welcome.
thanks,
Aaron
FYI: I spent a lot of time calibrating the path loss, so I'm reasonably confident that its not the issue...
thinking about it a bit more, a multiplicative noise source wouldn't explain what I'm seeing, because the radio is able to demodulate properly with adequate signal level. Also, if the noise was coming in directly to the radio card (from the PC for example), I would expect an LNA to improve the sensitivity. To me, it seems that either the demodulator is bad, or the noise is entering the channel (coaxial attenuators and cables) before any external LNA.
