realizing boolean function with 4bit lut
omen123
Newbie level 2
Newbie level 2
Germany/Darmstadt
Hi all,
How to realize boolean function like F(x,y,z)= xy+yz+xy`z+x`y`z` with 4bit LUTs without using any mux?
thanx,
omen
To answer the question exactly, you should better refer to an unequivocal logic syntax. If I understand the present example correct, it can be further minimized and most likely implemented by a single 4-input LUT. The functionality of LUTs however varies between vendors and FPGA families.
Can we ask why you need to do this?
For my master degree. I am doing animation portal representing how to realize boolean function with 1.MUXs 2. LUTs 3.FPGAs and 4. Decoders
Now my idea is to write down the truth table, splitting the function into 2 functions f1 and f2 (see the picture). I don`t know, what´s next :(
I am not certain if I understand correctly...
You can just pretend you have an extra input "w",so now you have 4 inputs: w,x,y,z. Then make your truth table same as before. And treat the "w" input as a DON'T CARE. That truth table (with 16 entries) gives you all the values for your 4-input LUT... Essentially you make 2 copies of the 8 entry truth table you posted above. One copy for the case where w=0, and one copy for when w=1. Which results in the LUT "not caring" about w .. the DON'T CARE.
Hope that helps...
please share your portal with all of us
