real time clock using 16f72
sajeev
Kerala-India
i have built a clock with common anode display.i used 32768 crystal to generate exact i second delay.The problem is that when interrupt occurs the display blinks for a small time,but we can see that change.I used 32 khz crystal as the system clock to save battery life.So anyone know how to solve this problem.I wrote the program in hitech c.
dear sanjeev,
please count the number of times the display routine is executed in one second, and the time in milliseconds taken by the display routine to complete. for viewing the display without any flickering its refresh routine should execute atleast > 30 times(every 1or 2 millisec) per second.
murugan
Salam,
I think you have just to increase the display times per second
I read that the eye can't distinguish blinking if it is repeated at least 50 times per second so u must repeat your display at most every 20mS.
Hope that i've helped u
Can you provide circuit diagram of the CLOCK ?
Salam,
