-- Company:
-- Engineer:
-- Create Date: 17:15:29 06/18/2017
-- Design Name:
-- Module Name: w5300_config - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.std_logic_1164.ALL;
USE ieee.std_logic_arith.ALL;
USE ieee.std_logic_unsigned.ALL;
--use STD.textio.all;
use ieee.std_logic_textio.all;
library UNISIM;
use UNISIM.VComponents.all;
use work.AVA6STest_Package.all;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity w5300_config is
port
o_Eth_CS : out std_logic;
o_Eth_RD : out std_logic;
o_Eth_WR : out std_logic;
o_Eth_RST : out std_logic;
io_Data : inout STD_LOGIC_VECTOR (7 downto 0);
io_Addr_Eth : inout STD_LOGIC_VECTOR (9 downto 0);
--o_USB_SLOE : out STD_LOGIC;
i_SYS_RESET : in STD_LOGIC;
-- x2 : out std_logic_vector (7 downto 0);
CLK_in : in std_logic;
-- flag : out std_logic;
CLK_out : out std_logic
end w5300_config;
architecture Behavioral of w5300_config is
signal clk_20,clk_10, Eth_RD : std_logic := '0';
signal delay_cnt : integer := 0;
signal x1 : std_logic_vector (2 downto 0):= "000";
component pll is
port
(-- Clock in ports
CLK_IN1 : in std_logic;
-- Clock out ports
CLK_OUT1 : out std_logic;
CLK_OUT2 :out std_logic
end component;
begin
s_Eth_ReConfig <= i_SYS_RESET;
clock_20 : pll port map ( CLK_in,clk_20,clk_10);
--CLK_out <= clk_20;
io_Addr_Eth <= s_W_ADDR;
--io_Data <= s_W_DATA_Out;
Inst_Data_IOBUF_Generate :
for i in 7 downto 0 generate
begin
Inst_Data_IOBUF : IOBUF
generic map (
--DRIVE => 24,
IOSTANDARD => "DEFAULT",
SLEW => "FAST")
port map (
O => s_DATA_In(i), -- Buffer output
IO => io_DATA(i), -- Buffer inout port (connect directly to top-level port)
I => s_DATA_Out(i), -- Buffer input
T => s_Data_DIR -- 3-state enable input, high=input, low=output
end generate;
s_DATA_Out <= s_W_DATA_Out; --when s_W_RD_WRB = '0' else s_W_DATA_In_Des;
s_W_DATA_In <= s_DATA_In;
s_Data_DIR <= s_W_RD_WRB;
--o_USB_SLOE <= '1';
Wiznet_Config_Process : process(clk_20)
begin
if rising_edge(clk_20) then
o_Eth_RST <= '1';
s_WriteTrig <= '0';
s_ReadTrig <= '0';
case s_Eth_Config_State is
when c_Eth_Config_State_Idle =>
s_Idle_cnt <= s_Idle_cnt + 1;
-- s_Interface_Type <= c_LAN_INTERFACE;
s_cnt_Wiznet_Config <= s_cnt_Wiznet_Config + 1;
if s_Wiznet_Ini_Reset = '0' then--Reset Cycle Time = 2us ; PLL Lock-in Time = 10ms
o_Eth_RST <= '0';
if s_cnt_Wiznet_Config > 20000 then -- 20000 * 50ns = 1ms -- min 2us
s_Wiznet_Ini_Reset <= '1';
s_cnt_Wiznet_Config <= 0;
--o_Eth_RST <= not o_Eth_RST ;--'0';
end if;
elsif s_Wiznet_Init_PLL = '0' then
if s_cnt_Wiznet_Config > 240000 then -- 240000 * 50ns = 12ms -- min 10ms
s_Wiznet_Init_PLL <= '1';
end if;
else
-- if s_Idle_cnt = 0 then
s_Eth_Config_State <= c_Eth_Config_State_Config1;
s_Index1 <= c_WIZNET_INIT_DATA_LENGTH_WR-1;
s_Index2 <= 0;
-- else
-- end if;
end if;
when c_Eth_Config_State_Config1 =>
s_W_ADDR_Des <= c_WIZNET_INIT_ADDR_WR(s_Index1);
s_W_DATA_Out_Des <= c_WIZNET_INIT_DATA_WR(s_Index1);
s_WriteTrig <= '1';
s_Index1 <= s_Index1 - 1;
if s_Index1 > 0 then
-- s_W_ADDR_Des <= c_WIZNET_INIT_ADDR_WR(s_Index1);
-- s_W_DATA_Out_Des <= c_WIZNET_INIT_DATA_WR(s_Index1);
s_Eth_Config_State <= c_Eth_Config_State_Config2;
elsif s_Index1 = 0 then
--s_Idle_cnt <= s_Idle_cnt + 1;
-- s_W_DATA_Out_Des <= x"20";
-- S0_CR1 <= x"20";
-- if (r_cnt )
-- s_Eth_Config_State <= c_Eth_Config_State_Config3;
s_Eth_Config_State <= c_Eth_Config_State_delay;
--else
-- s_Eth_Config_State <= c_Eth_Config_State_End;
end if;
when c_Eth_Config_State_Config2 =>
if s_W_DATA_Out_Des_Done = '1' then
end if;
when c_Eth_Config_State_delay =>
if delay_cnt < 5 then
delay_cnt <= delay_cnt + 1;
else
end if;
when c_Eth_Config_state_Config3 =>
--s_W_DATA_Out_Des <= (others => 'Z');
s_W_ADDR_Des <= c_WIZNET_INIT_ADDR_RD(s_Index2);
--s_W_DATA_Out_Des <= c_WIZNET_INIT_DATA_RD(s_Index);
s_ReadTrig <= '1';
s_Index2 <= s_Index2 + 1;
if s_Index2 < c_WIZNET_INIT_DATA_LENGTH_RD-1 then
s_Eth_Config_State <= c_Eth_Config_State_Config4;
else
end if;
when c_Eth_Config_State_config4 =>
if s_W_DATA_In_Des_Rdy = '1' then
end if;
when c_Eth_Config_State_End =>
-- s_Interface_Type <= c_USB_INTERFACE;
if s_Eth_ReConfig = '0' then
s_Wiznet_Ini_Reset <= '0';
s_Wiznet_Init_PLL <= '0';
s_Eth_Config_State <= c_Eth_Config_State_Idle;
end if;
when others =>
end case;
end if;
end process;
WiznetReadWrite_Process : process(clk_20)
begin
case s_Eth_RW_State is
when c_Eth_RW_State_Idle =>
o_Eth_CS <= '1';
o_Eth_WR <= '1';
o_Eth_RD <= '1';
--s_W_RD_WRB <= 'Z';
-- Eth_RD <= '1';
s_W_DATA_In_Des_Rdy <= '0';
s_W_DATA_Out_Des_Done <= '0';
-- s_W_ADDR <= (others => 'Z');
-- s_W_DATA_Out <= (others => 'Z');
-- io_Data <= (others => 'Z');
if s_WriteTrig = '1' then
s_W_RD_WRB <= '0';
o_Eth_CS <= '0';
s_W_ADDR <= s_W_ADDR_Des;
s_W_DATA_Out <= s_W_DATA_Out_Des;
s_Eth_RW_State <= c_Eth_RW_State_W1;
-- s_W_RD_WRB <= '0';
-- o_Eth_CS <= '0';
-- s_W_ADDR <= s_W_ADDR_Des;
-- io_Data <= s_W_DATA_Out_Des;
-- s_Eth_RW_State <= c_Eth_RW_State_W1;
elsif s_ReadTrig = '1' then
-- s_W_RD_WRB <= '1';
-- o_Eth_CS <= '0';
-- o_Eth_RD <= '0';
-- s_Eth_RW_State <= c_Eth_RW_State_R1;
-- Eth_RD <= '0';
s_W_RD_WRB <= '1';
o_Eth_CS <= '0';
o_Eth_RD <= '0';
end if;
when c_Eth_RW_State_W1 =>
o_Eth_WR <= '0';
-- Eth_RD <= '0';
s_W_DATA_Out_Des_Done <= '1';
s_Eth_RW_State <= c_Eth_RW_State_Idle;
when c_Eth_RW_State_R1 =>
o_Eth_RD <= '0';
-- Eth_RD <= '0';
-- x1(0) <= '1';
-- x1(2) <= '1';
-- s_W_DATA_In_Des_Rdy <= '1';
-- s_Eth_RW_State <= c_Eth_RW_State_Idle;
s_W_DATA_In_Des <= s_W_DATA_In;
-- s_W_DATA_In_Des <= io_Data;
when others =>
end case;
end if;
end process;
end behavioral;
-- Package File Template
-- Purpose: This package defines supplemental types, subtypes,
-- constants, and functions
-- To use any of the example code shown below, uncomment the lines and modify as necessary
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
package AVA6STest_Package is
SUBTYPE SUBTYPE_3Bit IS STD_LOGIC_VECTOR(3 DOWNTO 1);
TYPE Array_3Bit IS ARRAY (NATURAL RANGE <>) OF SUBTYPE_3Bit;
SUBTYPE SUBTYPE_5Bit IS STD_LOGIC_VECTOR(5 DOWNTO 1);
TYPE Array_5Bit IS ARRAY (NATURAL RANGE <>) OF SUBTYPE_5Bit;
SUBTYPE SUBTYPE_8Bit IS STD_LOGIC_VECTOR(7 DOWNTO 0);
TYPE Array_8Bit IS ARRAY (NATURAL RANGE <>) OF SUBTYPE_8Bit;
SUBTYPE SUBTYPE_10Bit IS STD_LOGIC_VECTOR(9 DOWNTO 0);
TYPE Array_10Bit IS ARRAY (NATURAL RANGE <>) OF SUBTYPE_10Bit;
SUBTYPE SUBTYPE_32Bit IS STD_LOGIC_VECTOR(31 DOWNTO 0);
TYPE Array_32Bit IS ARRAY (NATURAL RANGE <>) OF SUBTYPE_32Bit;
CONSTANT c_SPI_WIDTH : INTEGER := 8;
CONSTANT c_Wiznet_DataWidth : INTEGER := 8;
CONSTANT c_Wiznet_AddrWidth : INTEGER := 10;
constant c_USB_DataWidth : integer := 8;
constant c_USB_RAM_DataWidth_R : integer := 8;
constant c_USB_RD_AddrWidth : integer := 9;
constant c_USB_RAM_DataWidth_W : integer := 8;
constant c_USB_WR_AddrWidth : integer := 9;
constant c_USB_Bulklen_Out : integer := 512; --in samples
constant c_USB_Bulklen_In : integer := 512; --in samples
signal FREE_SIZE_TX : integer := 0;
signal S0_TX_FSR : Array_8Bit(2 downto 0) := (x"00",x"00",x"00");
signal S0_TX_FSR_v : std_logic_vector (23 downto 0):= (others => '0');
signal S0_TX_FSR_RD : std_logic := '0';
constant PACKET_SIZE_TOSEND : integer := 32*512;--*16bit --2048 bytes
constant S0_TX_FIFOR : std_logic_vector (9 downto 0) := "10"&x"2E";
--constant S0_CR : std_logic_vector (9 downto 0) := "10"&x"02";
constant S0_CR_SEND : std_logic_vector (15 downto 0) := x"0020";
-- constant S0_TX_WRSR : std_logic_vector (9 downto 0) := "10"&x"20";
-- constant S0_TX_WRSR2 : std_logic_vector (9 downto 0) := "10"&x"22";
constant S0_TX_WRSIZE : std_logic_vector (31 downto 0) := CONV_STD_LOGIC_VECTOR(PACKET_SIZE_TOSEND*2,32);--size dade ke gharar aast send shavad dar 32 bit neshan dade mishavad
constant c_WIZNET_INIT_DATA_LENGTH_WR : integer := 60; -- MAC + IP + SUB + GTW Header + ...
constant c_WIZNET_INIT_DATA_LENGTH_RD : integer := 2;-- Number of registers to be read
constant c_MAC_SOURCE_ADDRESS : Array_8Bit(5 downto 0) := (x"00", x"16", x"36", x"DE", x"58", x"F6");
constant c_IP_SOURCE_ADDRESS : Array_8Bit(3 downto 0) := (x"AC", x"10", x"0F", x"15"); -- IP = 192.168.0.20
constant c_SUB_MASK_ADDRESS : Array_8Bit(3 downto 0) := (x"FF", x"FF", x"FF", x"00"); -- SUB= 255.255.255.0
constant c_GATWAY_ADDRESS : Array_8Bit(3 downto 0) := (x"AC", x"10", x"0F", x"0A"); -- GTW = 192.168.0.1
-- constant c_IP_SOURCE_ADDRESS : Array_8Bit(3 downto 0) := (x"C0", x"A8", x"00", x"14"); -- IP = 192.168.0.20
-- constant c_SUB_MASK_ADDRESS : Array_8Bit(3 downto 0) := (x"FF", x"FF", x"FF", x"00"); -- SUB= 255.255.255.0
-- constant c_GATWAY_ADDRESS : Array_8Bit(3 downto 0) := (x"C0", x"A8", x"00", x"01"); -- GTW = 192.168.0.1
constant c_IP_DESTINATION_ADDRESS : Array_8Bit(3 downto 0) := (x"AC", x"10", x"0F", x"8E"); -- IP = 192.168.0.20
-- Sn_MR = 0x02; /* sets UDP mode */
-- Sn_PORTR = source_port; /* sets source port number */
-- Sn_CR = OPEN;
constant MTYPER0 : std_logic_vector (7 downto 0) := x"FF";
constant MTYPER1 : std_logic_vector (7 downto 0) := x"00";
constant TMSR0 : std_logic_vector (7 downto 0) := x"08";
constant TMSR1 : std_logic_vector (7 downto 0) := x"08";
constant TMSR2 : std_logic_vector (7 downto 0) := x"08";
constant TMSR3 : std_logic_vector (7 downto 0) := x"08";
constant TMSR4 : std_logic_vector (7 downto 0) := x"08";
constant TMSR5 : std_logic_vector (7 downto 0) := x"08";
constant TMSR6 : std_logic_vector (7 downto 0) := x"08";
constant TMSR7 : std_logic_vector (7 downto 0) := x"08";
constant RMSR0 : std_logic_vector (7 downto 0) := x"08";
constant RMSR1 : std_logic_vector (7 downto 0) := x"08";
constant RMSR2 : std_logic_vector (7 downto 0) := x"08";
constant RMSR3 : std_logic_vector (7 downto 0) := x"08";
constant RMSR4 : std_logic_vector (7 downto 0) := x"08";
constant RMSR5 : std_logic_vector (7 downto 0) := x"08";
constant RMSR6 : std_logic_vector (7 downto 0) := x"08";
constant RMSR7 : std_logic_vector (7 downto 0) := x"08";
constant c_S0_MR1 : std_logic_vector (7 downto 0) := x"02"; -- UDP Mode
constant c_S0_PORTR0 : std_logic_vector (7 downto 0) := x"13";
constant c_S0_PORTR1 : std_logic_vector (7 downto 0) := x"88"; -- port 5000
constant C_S0_DPORTR0 :std_logic_vector (7 downto 0) := x"13";
constant C_S0_DPORTR1 :std_logic_vector (7 downto 0) := x"88";--- Destination Port 5000
signal S0_CR1 : std_logic_vector (7 downto 0) := x"01"; --open
--constant S0_TX_WRSR0 : std_logic_vector (7 downto 0) := x"00";
constant S0_TX_WRSR1 : std_logic_vector (7 downto 0) := x"00";
constant S0_TX_WRSR2 : std_logic_vector (7 downto 0) := x"00";
constant S0_TX_WRSR3 : std_logic_vector (7 downto 0) := x"0A";
signal c_WIZNET_INIT_DATA_WR : Array_8Bit(c_WIZNET_INIT_DATA_LENGTH_WR-1 downto 0) :=
-- Source MAC Address
c_WIZNET_INIT_DATA_LENGTH_WR-1 => c_MAC_SOURCE_ADDRESS(5),
c_WIZNET_INIT_DATA_LENGTH_WR-2 => c_MAC_SOURCE_ADDRESS(4),
c_WIZNET_INIT_DATA_LENGTH_WR-3 => c_MAC_SOURCE_ADDRESS(3),
c_WIZNET_INIT_DATA_LENGTH_WR-4 => c_MAC_SOURCE_ADDRESS(2),
c_WIZNET_INIT_DATA_LENGTH_WR-5 => c_MAC_SOURCE_ADDRESS(1),
c_WIZNET_INIT_DATA_LENGTH_WR-6 => c_MAC_SOURCE_ADDRESS(0),
-- Source IP Address
c_WIZNET_INIT_DATA_LENGTH_WR-7 => c_IP_SOURCE_ADDRESS(3),
c_WIZNET_INIT_DATA_LENGTH_WR-8 => c_IP_SOURCE_ADDRESS(2),
c_WIZNET_INIT_DATA_LENGTH_WR-9 => c_IP_SOURCE_ADDRESS(1),
c_WIZNET_INIT_DATA_LENGTH_WR-10 => c_IP_SOURCE_ADDRESS(0),
-- SUBNET MASK Address
c_WIZNET_INIT_DATA_LENGTH_WR-11 => c_SUB_MASK_ADDRESS(3),
c_WIZNET_INIT_DATA_LENGTH_WR-12 => c_SUB_MASK_ADDRESS(2),
c_WIZNET_INIT_DATA_LENGTH_WR-13 => c_SUB_MASK_ADDRESS(1),
c_WIZNET_INIT_DATA_LENGTH_WR-14 => c_SUB_MASK_ADDRESS(0),
-- GATWAY Address
c_WIZNET_INIT_DATA_LENGTH_WR-15 => c_GATWAY_ADDRESS(3),
c_WIZNET_INIT_DATA_LENGTH_WR-16 => c_GATWAY_ADDRESS(2),
c_WIZNET_INIT_DATA_LENGTH_WR-17 => c_GATWAY_ADDRESS(1),
c_WIZNET_INIT_DATA_LENGTH_WR-18 => c_GATWAY_ADDRESS(0),
--TX RX MEMORY
c_WIZNET_INIT_DATA_LENGTH_WR-19 => TMSR0,
c_WIZNET_INIT_DATA_LENGTH_WR-20 => TMSR1,
c_WIZNET_INIT_DATA_LENGTH_WR-21 => TMSR2,
c_WIZNET_INIT_DATA_LENGTH_WR-22 => TMSR3,
c_WIZNET_INIT_DATA_LENGTH_WR-23 => TMSR4,
c_WIZNET_INIT_DATA_LENGTH_WR-24 => TMSR5,
c_WIZNET_INIT_DATA_LENGTH_WR-25 => TMSR6,
c_WIZNET_INIT_DATA_LENGTH_WR-26 => TMSR7,
c_WIZNET_INIT_DATA_LENGTH_WR-27 => RMSR0,
c_WIZNET_INIT_DATA_LENGTH_WR-28 => RMSR1,
c_WIZNET_INIT_DATA_LENGTH_WR-29 => RMSR2,
c_WIZNET_INIT_DATA_LENGTH_WR-30 => RMSR3,
c_WIZNET_INIT_DATA_LENGTH_WR-31 => RMSR4,
c_WIZNET_INIT_DATA_LENGTH_WR-32 => RMSR5,
c_WIZNET_INIT_DATA_LENGTH_WR-33 => RMSR6,
c_WIZNET_INIT_DATA_LENGTH_WR-34 => RMSR7,
c_WIZNET_INIT_DATA_LENGTH_WR-35 => MTYPER0,
c_WIZNET_INIT_DATA_LENGTH_WR-36 => MTYPER1,
-- Protocol : UDP
c_WIZNET_INIT_DATA_LENGTH_WR-37 => c_S0_MR1,
-- PORT Adress
c_WIZNET_INIT_DATA_LENGTH_WR-38 => c_S0_PORTR0,
c_WIZNET_INIT_DATA_LENGTH_WR-39 => c_S0_PORTR1,
c_WIZNET_INIT_DATA_LENGTH_WR-40 => S0_CR1,
c_WIZNET_INIT_DATA_LENGTH_WR-41 => c_IP_DESTINATION_ADDRESS(3),
c_WIZNET_INIT_DATA_LENGTH_WR-42 => c_IP_DESTINATION_ADDRESS(2),
c_WIZNET_INIT_DATA_LENGTH_WR-43 => c_IP_DESTINATION_ADDRESS(1),
c_WIZNET_INIT_DATA_LENGTH_WR-44 => c_IP_DESTINATION_ADDRESS(0),
c_WIZNET_INIT_DATA_LENGTH_WR-45 => C_S0_DPORTR0,
c_WIZNET_INIT_DATA_LENGTH_WR-46 => c_S0_DPORTR1,
c_WIZNET_INIT_DATA_LENGTH_WR-47 => S0_TX_WRSR1,
c_WIZNET_INIT_DATA_LENGTH_WR-48 => S0_TX_WRSR2,
c_WIZNET_INIT_DATA_LENGTH_WR-49 => S0_TX_WRSR3,
c_WIZNET_INIT_DATA_LENGTH_WR-50 => x"00",
c_WIZNET_INIT_DATA_LENGTH_WR-51 => x"00",
c_WIZNET_INIT_DATA_LENGTH_WR-52 => x"00",
c_WIZNET_INIT_DATA_LENGTH_WR-53 => x"00",
c_WIZNET_INIT_DATA_LENGTH_WR-54 => x"00",
c_WIZNET_INIT_DATA_LENGTH_WR-55 => x"00",
c_WIZNET_INIT_DATA_LENGTH_WR-56 => x"00",
c_WIZNET_INIT_DATA_LENGTH_WR-57 => x"00",
c_WIZNET_INIT_DATA_LENGTH_WR-58 => x"00",
c_WIZNET_INIT_DATA_LENGTH_WR-59 => x"00",
c_WIZNET_INIT_DATA_LENGTH_WR-60 => x"20"
--c_WIZNET_INIT_DATA_LENGTH_WR-61 => x"10"
constant c_WIZNET_INIT_ADDR_WR : Array_10Bit(c_WIZNET_INIT_DATA_LENGTH_WR-1 downto 0) :=
c_WIZNET_INIT_DATA_LENGTH_WR-1 => "00"&x"08",
c_WIZNET_INIT_DATA_LENGTH_WR-2 => "00"&x"09",
c_WIZNET_INIT_DATA_LENGTH_WR-3 => "00"&x"0A",
c_WIZNET_INIT_DATA_LENGTH_WR-4 => "00"&x"0B",
c_WIZNET_INIT_DATA_LENGTH_WR-5 => "00"&x"0C",
c_WIZNET_INIT_DATA_LENGTH_WR-6 => "00"&x"0D",
c_WIZNET_INIT_DATA_LENGTH_WR-7 => "00"&x"18",
c_WIZNET_INIT_DATA_LENGTH_WR-8 => "00"&x"19",
c_WIZNET_INIT_DATA_LENGTH_WR-9 => "00"&x"1A",
c_WIZNET_INIT_DATA_LENGTH_WR-10 => "00"&x"1B",
c_WIZNET_INIT_DATA_LENGTH_WR-11 => "00"&x"14",
c_WIZNET_INIT_DATA_LENGTH_WR-12 => "00"&x"15",
c_WIZNET_INIT_DATA_LENGTH_WR-13 => "00"&x"16",
c_WIZNET_INIT_DATA_LENGTH_WR-14 => "00"&x"17",
-- GATWAY Address
c_WIZNET_INIT_DATA_LENGTH_WR-15 => "00"&x"10",
c_WIZNET_INIT_DATA_LENGTH_WR-16 => "00"&x"11",
c_WIZNET_INIT_DATA_LENGTH_WR-17 => "00"&x"12",
c_WIZNET_INIT_DATA_LENGTH_WR-18 => "00"&x"13",
-- --tx rx memory
c_WIZNET_INIT_DATA_LENGTH_WR-19 => "00"&x"20",
c_WIZNET_INIT_DATA_LENGTH_WR-20 => "00"&x"21",
c_WIZNET_INIT_DATA_LENGTH_WR-21 => "00"&x"22",
c_WIZNET_INIT_DATA_LENGTH_WR-22 => "00"&x"23",
c_WIZNET_INIT_DATA_LENGTH_WR-23 => "00"&x"24",
c_WIZNET_INIT_DATA_LENGTH_WR-24 => "00"&x"25",
c_WIZNET_INIT_DATA_LENGTH_WR-25 => "00"&x"26",
c_WIZNET_INIT_DATA_LENGTH_WR-26 => "00"&x"27",
c_WIZNET_INIT_DATA_LENGTH_WR-27 => "00"&x"28",
c_WIZNET_INIT_DATA_LENGTH_WR-28 => "00"&x"29",
c_WIZNET_INIT_DATA_LENGTH_WR-29 => "00"&x"2A",
c_WIZNET_INIT_DATA_LENGTH_WR-30 => "00"&x"2B",
c_WIZNET_INIT_DATA_LENGTH_WR-31 => "00"&x"2C",
c_WIZNET_INIT_DATA_LENGTH_WR-32 => "00"&x"2D",
c_WIZNET_INIT_DATA_LENGTH_WR-33 => "00"&x"2E",
c_WIZNET_INIT_DATA_LENGTH_WR-34 => "00"&x"2F",
c_WIZNET_INIT_DATA_LENGTH_WR-35 => "00"&x"30",
c_WIZNET_INIT_DATA_LENGTH_WR-36 => "00"&x"31",
-- MODE register Address
c_WIZNET_INIT_DATA_LENGTH_WR-37 => "10"&x"01",
-- PORT Adress
c_WIZNET_INIT_DATA_LENGTH_WR-38 => "10"&x"0A",
c_WIZNET_INIT_DATA_LENGTH_WR-39 => "10"&x"0B",
--Command Register Adress
c_WIZNET_INIT_DATA_LENGTH_WR-40 => "10"&x"03",
-- -- Destination IP Address
c_WIZNET_INIT_DATA_LENGTH_WR-41 => "10"&x"14",
c_WIZNET_INIT_DATA_LENGTH_WR-42=> "10"&x"15",
c_WIZNET_INIT_DATA_LENGTH_WR-43 => "10"&x"16",
c_WIZNET_INIT_DATA_LENGTH_WR-44 => "10"&x"17",
--Destination PORT Adress
c_WIZNET_INIT_DATA_LENGTH_WR-45 => "10"&x"12",
c_WIZNET_INIT_DATA_LENGTH_WR-46 => "10"&x"13",
c_WIZNET_INIT_DATA_LENGTH_WR-47 => "10"&x"21",
c_WIZNET_INIT_DATA_LENGTH_WR-48 => "10"&x"22",
c_WIZNET_INIT_DATA_LENGTH_WR-49 => "10"&x"23",
c_WIZNET_INIT_DATA_LENGTH_WR-50 => "10"&x"2E",
c_WIZNET_INIT_DATA_LENGTH_WR-51 => "10"&x"2F",
c_WIZNET_INIT_DATA_LENGTH_WR-52 => "10"&x"2E",
c_WIZNET_INIT_DATA_LENGTH_WR-53 => "10"&x"2F",
c_WIZNET_INIT_DATA_LENGTH_WR-54 => "10"&x"2E",
c_WIZNET_INIT_DATA_LENGTH_WR-55 => "10"&x"2F",
c_WIZNET_INIT_DATA_LENGTH_WR-56 => "10"&x"2E",
c_WIZNET_INIT_DATA_LENGTH_WR-57 => "10"&x"2F",
c_WIZNET_INIT_DATA_LENGTH_WR-58 => "10"&x"2E",
c_WIZNET_INIT_DATA_LENGTH_WR-59 => "10"&x"2F",
-- Command Register Adress
c_WIZNET_INIT_DATA_LENGTH_WR-60 => "10"&x"03"
--c_WIZNET_INIT_DATA_LENGTH_WR-61 => "10"&x"03"
--constant c_WIZNET_INIT_DATA_RD : Array_8Bit(c_WIZNET_INIT_DATA_LENGTH_RD-1 downto 0); --:=
--c_WIZNET_INIT_DATA_LENGTH_RD-1 => x"22"
constant c_WIZNET_INIT_ADDR_RD : Array_10Bit(c_WIZNET_INIT_DATA_LENGTH_RD-1 downto 0) :=
--c_WIZNET_INIT_DATA_LENGTH_RD-1 => "10"&x"09"
-- c_WIZNET_INIT_DATA_LENGTH_RD-1 => "10"&x"03"
--c_WIZNET_INIT_DATA_LENGTH_RD-1 => "10"&x"25",
-- c_WIZNET_INIT_DATA_LENGTH_RD-1 => "10"&x"03",
c_WIZNET_INIT_DATA_LENGTH_RD-2 => "10"&x"26"
-- c_WIZNET_INIT_DATA_LENGTH_RD-2 => "10"&x"26",
-- c_WIZNET_INIT_DATA_LENGTH_RD-3 => "10"&x"27"
-- c_WIZNET_INIT_DATA_LENGTH_RD-4 => "10"&x"03"
constant s_WiznetState_Idle : integer := 0;
constant s_WiznetState_SOF1 : integer := 1;
constant s_WiznetState_SOF2 : integer := 2;
constant s_WiznetState_WriteAdd1 : integer := 3;
constant s_WiznetState_WriteAdd2 : integer := 4;
constant s_WiznetState_WriteData1 : integer := 5;
constant s_WiznetState_WriteData2 : integer := 6;
constant s_WiznetState_WriteWRB : integer := 7;
constant s_WiznetState_ReadAdd1 : integer := 8;
constant s_WiznetState_ReadAdd2 : integer := 9;
constant s_WiznetState_ReadData1 : integer := 10;
constant s_WiznetState_ReadData2 : integer := 11;
constant s_WiznetState_ReadData3 : integer := 12;
constant s_WiznetState_ReadData4 : integer := 13;
constant s_WiznetState_WriteCSB : integer := 14;
constant s_WiznetState_DS1 : integer := 15;
signal s_WiznetState : integer range 0 to 30:= s_WiznetState_Idle;
signal delay_counter_W_State : integer range 0 to 100 := 0;
constant c_Eth_Config_State_Idle : integer := 0;
constant c_Eth_Config_State_Config1 : integer := 1;
constant c_Eth_Config_State_Config2 : integer := 2;
constant c_Eth_Config_State_End : integer := 3;
constant c_Eth_Config_State_Config3 : integer := 4;
constant c_Eth_Config_State_Config4 : integer := 5;
constant c_Eth_Config_State_delay : integer := 6;
signal s_Eth_Config_State : integer range 0 to 10:= c_Eth_Config_State_Idle;
constant c_Eth_RW_State_Idle : std_logic_vector(1 downto 0) := "00";
constant c_Eth_RW_State_W1 : std_logic_vector(1 downto 0) := "01";
constant c_Eth_RW_State_R1 : std_logic_vector(1 downto 0) := "10";
signal s_Eth_RW_State : std_logic_vector(1 downto 0):= c_Eth_RW_State_Idle;
signal s_Idle_cnt : integer := 0;
signal s_cnt_Wiznet_Config : integer := 0;
signal s_Index1 : integer range 0 to c_WIZNET_INIT_DATA_LENGTH_WR-1 := 0;
signal s_Index2 : integer range 0 to c_WIZNET_INIT_DATA_LENGTH_RD-1 := 0;
signal s_Wiznet_Ini_Reset : std_logic := '0';
signal s_Wiznet_Init_PLL : std_logic := '0';
signal s_WriteTrig : std_logic := '0';
signal s_ReadTrig : std_logic := '0';
signal s_W_DATA_Out_Des_Done : std_logic := '0';
signal s_W_DATA_In_Des_Rdy : std_logic := '0';
signal s_Eth_ReConfig : std_logic := '0';
signal s_W_DATA_In_Des : std_logic_vector (c_Wiznet_DataWidth-1 downto 0) := (others => ('0'));
signal s_W_DATA_Out_Des : std_logic_vector (c_Wiznet_DataWidth-1 downto 0) := (others => ('0'));
signal s_W_ADDR_Des : std_logic_vector(c_Wiznet_AddrWidth-1 downto 0):= (others => ('0'));
signal s_W_DATA_In : std_logic_vector (c_Wiznet_DataWidth-1 downto 0) := (others => ('0'));
signal s_W_DATA_Out : std_logic_vector (c_Wiznet_DataWidth-1 downto 0) := (others => ('0'));
signal s_W_ADDR : std_logic_vector(c_Wiznet_AddrWidth-1 downto 0):= (others => ('0'));
signal s_W_RD_WRB : std_logic := '0';
signal s_DATA_In : std_logic_vector (7 downto 0) := (others => ('0'));
signal s_DATA_Out : std_logic_vector (7 downto 0) := (others => ('0'));
signal s_interface_type : std_logic := '0';
signal s_data_dir : std_logic := '0';
end AVA6STest_Package;
