reading frequency using pic16f877a
Qaisar Azeemi
Full Member level 5
Peshawar, Pakistan, Pakistan
Hi all;
i want to measure the frequency of a sin wave passed through HEF4093BE NAND gate Schmitt trigger to be furnished and this frequency is feeded into pin RA2 of PIC16F877A; and from this pin i want to read the frequency. i made the following code for that purpose but instead of reading the frequency it is counting the numbers with a very high speed i think with the clock speed of my 4MHz crystal. plz analyze my code and tell me the mistake. (NOTE: i don't want to use counter pins).
Here are frequency related parts of my code to make it understandable for you.
void interrupt()
     if(PIR1.TMR1IF==1)
        frq=1;
void main()
ADCON1=0x06;   // adc reg initialization
INTCON=0xA0;  // for timer0  ; interrupt reg initilization
 TRISA = 0xFF;     // port A as input
      Lcd_Cmd(_LCD_CLEAR);                    // Clear display
      Lcd_Cmd(_LCD_CURSOR_OFF);
      Lcd_Cmd(_LCD_MOVE_CURSOR_RIGHT);
      Lcd_Out(1,1,CopyConst2Ram(msg,fv));   // Write text in first row
     T1CON.TMR1ON=0;
     PIR1.TMR1IF=0;
     TMR1L=0XEE;    // value loaded for 1 second delay.
     TMR1H=0X85;
              j==1;
              frq=0;
              while(j==1)
                         while(G_freq==1)
                            {G++;}
                                    IntToStr(G,string);
                                    Lcd_Out(2,2,string);
                                    Lcd_Out_CP("Hz");
                         if(mains==P)
                         {j=0;}
                         if(frq==1)
                             k++;
                             T1CON.TMR1ON=0;
                             PIR1.TMR1IF=0;
                             TMR1H=0X85;
                                if(k=4)
                                    IntToStr(G,string);
                                    Lcd_Out_CP("Hz");
                                    Delay_ms(1000);
                                    G=0;
                                    k=0;
                             T1CON.TMR1ON=1;
                             frq=0;
where
#define genr PORTA.F0
#define mains PORTA.F1
#define G_freq PORTA.F2
const char fv[] = "Frequency  Volts";
unsigned char frq=0;
unsigned int j=1,G=0,k=0;
You have to use TOCKI pin to count pulses. There is only one interrupt RB0. How can you use RA2?
acctually a developed hardware is given to me by the company for that i have to program the microcontroller. they have used two pins RA2 and RA3 , RA2 is i think for frequency and i don't know the other's purpose. plz see the schemetic below and analyze the port A.
