reading an analog current signal into a pic micro
dmta
Member level 2
Member level 2
Earth
Hi all,
I have 2 H bridges that are powering two DC motors. The total current going into the motors (5A) is being measured by an INA193. I want to read in the average current (RMS would be better) going into the motors. For this I am low pass filtering the current output using two LPFs in series. I am using the attached circuit but the values are not quite stable. What can I do to solve this?
I am also open to doing some calculation in the micro which is a PIC18f4431 run at 10MIPs. The problem is that the process slows down when I try to average the values using the code. I am also running a motor speed PID loop inside the micro.
Regards
