Hello, I have a Lead Acid battery 6V and I want to meter its voltage using Arduino's ADC. I want to do this with some kind of isolation between the battery and the ADC. Can this happen? What component/circuit should I use to build this?
Why do you need isolation? What isolation voltage?
A somehow good solution may be more effort and higher cost than the arduino itself.
What voltage range (of interest), signal frequency, precision, resolution? What sample rate?
I have a circuit with Arduino, sensors and a battery (6Volt) and I want to meter the battery's voltage using one of Arduino's ADC. But I do not thing it is a good idea to use directly connection of the battery to the ADC (even with a voltage divider), because maybe I face some short-circuits, I do not know for sure...! That's why I thought of using an isolator. As far as the resolution is concerned, Arduino provides 1024 bits, and the frequency: 1Hz is ok, and even lower...
you worry about short circuits... and why do you think you can´t create a short circuit with some isolation?
I think the more devices you use the higher is the chance for a mistake.
I think the voltage divider solution (you need in most isolated case, too) is a very simple and rugged solution.
Choose the resistor values that the current isl imited to a safe value.
It´s used million times in many devices.
How is your arduino powered? From the same battery? --> Then isolation definitely makes no sense.
BTW: There are many, many discussions and descriptions about battery voltage measurement.
Do a forum search and/or an internet search.
