Read Xbee analog data
icemetal
Member level 2
I have to xbee modules, and I want to be able to read a 10K potentiometer wireless, I had connected the pot to ADC0 of one of the xbee modules and I adjusted the pot but on the other side I dont see any information but when I send serial data I can see it, is any other configuration I should do?
Are the XBees Series 1 or Series 2?
Have you set the sample rate?
ATIR16  = sample rate 22 milliseconds (hex 16)
BigDog
I have 2 Xbee pro, it does not said what series they are, and when I type this
+++OK
ATIR16
ERROR
that's what I get
We first need to identify the type and series of your XBee Modules.
Do you have X-CTU installed?
If so, once connected to one of the XBee Modules using X-CTU, navigate to the "Modem Configuration" Tab and then press "Read" button.
Record the firmware type which appears under "Function Set" and the "Version" drop down menus.
Reply back with this information for both the XBee Modules.
Once we know the firmware type and version we can proceed.
BigDog
it says 1084
You have two XBEE PRO Series 1 modules.
You may want to upgrade to a more recent firmware level, you current version 1084 is several revisions back.
Meanwhile, I'll see if I can put together a step by step example of how to properly configure your units for "Direct I/O" mode.
BigDog
OK I know what you mean I updated the firmware to "10EC" and that commands work
+++OK
ATIR16
OK
ATWR
OK
One Xbee is connected to X-CTU and the other it has a 10K pot to ADC0
I put that at command on both but nothing happens yet,
---------- Post added at 07:10 ---------- Previous post was at 06:51 ----------
THANKS BIGDOG, I figure out
I'm glad you've got it figured out.
I was just typing in a step-by-step procedure.
I would recommend keeping the output impedance of you analog signal source in the 2kΩ - 3kΩ range rather than the 10kΩ pot you are currently using.
A fairly good text on the XBee modules is the following:
Building Wireless Sensor Networks: with ZigBee, XBee, Arduino, and Processing
The text utilizes Series 2 modules in its examples and covers various ZigBee Mesh Network configurations as well as "Direct I/O".
You may also find the following group I maintain of interest:
Embedded Wireless Networks - WiFi, ZigBee, MiWi, 802.15.4, Bluetooth & RF
Good Luck with your project,
BigDog
