Read Write Eeprom in Bascom
erwin4838
Member level 1
Tangerang-indonesia
dear
All
i need your help ,i have a timer project and counter,i want to if power switch off and then on,timer is continu counting not counting in a new begin,example :
last power switch off timer in position 3 sec,after power switch on timer is continu counting 4sec,not start in begine 0 sec
this is a sample source code :
thanks for you attention
Timer and Counter? Sorry, i'm not sure what you want. Do you mean, it's like a Digital scoring board? Please try this, you can modify it as you like.
Code Basic4GL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
$regfile = "attiny2313.dat"
$crystal = 8000000
Dim Multiplier As Byte
Dim Second As Byte
Dim Score As Byte
Ddrd = &H00 'Input
Portd = &FF 'Internal Pull-Up
Ddrb = &HFF 'Output
Readeeprom Second , 100  'Read EEPROM address 100
Readeeprom Score 'Read next address
'8 Mhz / 64 = 125 Khz = 8 uS
'8 uS x 25,000 = 200,000 uS = 0.2 S
'200000 = &H61A8
'Multiply with 5 = 1 S
'So hard to Config timer as CTC in Bascom. So we make it like this
'Manual Configuration
'Config Timer1 (16-bit)
'OC1A-OC1B disconnected
'COM1A1-COM1A0 = 0-0, Normal Port Operation
'COM1B1-COM1B0 = 0-0, Normal Port Operation
'FOC1A-FOC1B = 0-0, No Force
'ICNC1 = 0, No Noise Canceler
'ICES1 = 0, Falling Edge
'WGM13-WGM12-WGM11-WGM10 = 0-1-0-0, CTC Top OCR1A
'CS12-CS11-CS10 = 0-1-1, Fclock/64
Tccr1a = &B00000000
Tccr1b = &B00001011
'Timer 1 will count from &H0000 to &H61A8 (=25,000 clocks)
'Start from &H0000
'Tcnt1h = 0
'Tcnt1l = 0
Timer1 = 0
'Fill output compare register with &H61A8
'Ocr1ah = &H61
'Ocr1al = &HA8
Compare1a = 25000
Multiplier = 0
'Enable Interrupt Comper1a
Enable Compare1a
Enable Interrupts
'Pointed interrupt vector to Multiply (occured when TCCNT match with OCR1A)
On Compare1a Multiply
Do
  Do
  Loop until Pind.5 = 0
  Waitms 100
  'Increment counter but don't save to eeprom here
  Incr Score
  Portb = Score
  Do
  Loop until Pind.5 = 1
  Waitms 100
Loop
End
Multiply:
Timer1 = 40536
Incr Multiplier
If Multiplier = 5 Then
Multiplier = 0
Incr Second
'Saving all data here to avoid double saving condition when interrupt occured.
Writeeeprom Second , 100
Waitms 10
Writeeeprom Score
End If
Return
i'm sory i was begin browsing again,cause my connection have a trouble,yes its not a counter,only timer
ok i'll try,thks
