rcc-nova
Newbie level 1
- Joined
- Feb 28, 2013
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,299
RCC NOVA is a Polish company located in Cracow designing and producing universal and dedicated controllers based on modern microprocessors.
Our controllers are individually programmable according to the customer. This allows them to be used in automatic systems as well as for atypical devices control.
At present we offer 2 devices: miniNOVA and compactNOVA.
miniNOVA:
- 8 transistor power outputs (up to 35W) with self-diagnostic system
- 6 digital inputs (including 2 fast, 50kHz)
- communication using RS-485 bus
- possibility to connect other devices using I2C or 1-Wire bus
- power supply: 12-36 VDC (nominal 24 VDC)
- durable housing (IP65)
- compact sized: 125x80x40 mm
Sample usage:
- Pneumatic valve system controller.
- Control unit for executive system, durable housing allows mounting directly on controlled device.
- Small size, compact design and communication using RS-485 bus allows to use device as distributed IN/OUT unit.
compactNOVA:
- 6 relay outputs
- 8 transistor outputs
- 12 opto-isolated digital inputs (4 fast, 50kHz)
- 2 analog inputs 0-10V
- microSD handling
- real time clock
- power supply:12-36 VDC (nominal 24 VDC)
- compact sized: 125x95x60 mm
- two communication ports: RS-485 and RS-482/RS232/USB
Sample usage:
- Master unit for e.g. miniNOVA controller, 1-1 or 1-x connection
- Connection of GPS unit and GSM modem allows to create a mobile, distributed control system with remote access e.g. mobile information board for railway
- Master device for other distributed automatic units
- IN/OUT system for PC computers to integrate signals of controlled objects with computer
implementation of advanced control algorithms,
- Data logger which acquire external data on microSD card, e.g. monitoring of environmental conditions or events.
For more information please visit www.rcc-nova.pl
miniNOVA:
Sample usage:
compactNOVA:
- 6 relay outputs
- microSD handling
- real time clock
Sample usage:
