machasm
Newbie level 2
Hi all,
I am new to this forum and have come here with an electronic background as a technician rather than a design engineer.
What I am after is a voltage regulator circuit with the following criteria.
1) Input voltage will be from Li-Po battery 2S or 3S (7.4V to 11.1V nominal fully charged 8.4V to 12.6V).
2) Be able to accept 2 input sources simultaneously for redundancy so if one cell fails then the reg will still work off the other cell.
3) LED indicators for voltage levels of both power packs.
4) One 5.2V output with max sustained 5A current.
5) an additional programmable output in steps of 6V, 6.8V, 8V with a max continuous current of 10A.
6)Low voltage alarm in the form of a high vis LED.
7) a remote mounted switch to be able to turn regulator on or off negating the need to remove the packs.
8) An on board glow driver actuated using a momentary push switch and giving a voltage of 1.2V for 15 secs (not sure of the current requirements yet but is needed to ignite an RC glow plug such as an OS #8)
9) must remain relatively small so that it can be mounted on an RC helicopter though may contain cooling fins to allow good heat dissappation.
10) Could be linear or switching although if switching, RF must not interfere with 2.4Ghz radio signal.
11) Preferably constructed from SMD devices that can be bonded due to vibrations on Helicopters.
Anyone got any ideas or pointers. I know its quite a handful especially for a first post!
Thanks guys.
Ade.
Thanks guys.
Ade.
