[SOLVED] RC Filter Constant Voltage Converter
iimagine
Member level 5
Member level 5
RC Filter Continuous Voltage Out
I need a little help here. I want to implement a Highpass filter that outputs a continuous voltage waveform. I have experiment this on Falstad's java sim and able to get it to produce what I want, somewhat... The problem is how do I simulate this in LTSpice? Is there any problem(s) with this circuit of mine? Are there any other way of doing it?
PS: I prefer using discrete components if possible since I want to learn more about them.
Thanks
Re: RC Filter Continuous Voltage Out
Thanks
It is a very simple high-pass - in principle, first-order only. If you are satisfied - good enough.
Otherwise, you should use one of the classical forms for high-pass networks (passive or active).
