d123
Advanced Member level 5
iC = C*(dVc/dt)
1)
(i) a) Is dt instantaneous or conditioned by RC selection?
b) How is Rsource relevant, or not, to dt?
(ii) In schematic A, what would dt be: >0s or 10ms?
2)
(i) Does ib = iC?
(ii) If so, presumably iC must be calculated for desired ib?
3)
At t = >0s (when pushbutton is initially pressed), does VR = Vin immediately? I thought so.
4)
If ib = iC, which schematic is most helpful for protecting the BJT base from excessive input currents: A, B or C?
5)
(i) As the differentiator swings below ground at turn-off of a square wave input signal as far as it rises above ground at turn-on of input signal, what would happen at the 'Vin' node at input turn-off?
(ii) How can the negative-going excursion be limited (in the 'A' schematic) - presumably/possibly a diode from ground to tbe Vin node, anode to ground and cathode to Vin?
(iii) How would the negative-going excursion affect other components/voltages/ground/voltage references on a pcb with a solid ground plane?
Children's doodles attached...
Thanks.
iC = C*(dVc/dt)
1)
2)
(i) Does ib = iC?
3)
4)
5)
Thanks.
