Rao-Wilton-Glisson (RWG) Codes
K&amp#305z&amp#305
Junior Member level 3
Ankara / Turkey
Hi
I am studying on RWG Function. I used Makarov's book and codes. However, his code does not work for small object. For example when the square plate in 0.15 lambda, it does not match with RWG's original paper's results. I need codes that is based on RWG's original paper. Could you share an example code, for example for square plate.
Thank you, so much
