Looks like a GDSII MASK layer description:
An example MASK list - embedded in a GDSII stream file - looks like this:
1 5-7 10 ; 0-255 (hex notation represented in ASCII format).
Stream-in and stream-out layer map tables should have a unique assignment between layer-name layer-purpose stream-layer-number stream-data-type
ddis, I would just stream in the inductor. Cadence would assign any layer to your inductor metal etc. Then just go in to it and change layers as they suppose to be ba hand,. For inductor it is not so difficult. Way easier than figuring our the layer map.
