arunkumarnellur
Newbie level 1
- Joined
- Nov 11, 2006
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,306
Hello EDABoard:
I am trying the following snippet in VMM (pkt randomization with an atomic generator).
The output shows 'pkt' attributes set to 'zero' where as the randomized attributes are expected.
Could somebody suggest where the code needs to be fixed?
Thanks
Arun N
command to run: vcs -full64 -sverilog -licqueue -ntb_opts rvm -R channel_connection.sv
Output:
time: 0
time: 200
[] vari = 32'h00000000; vari2 = 32'h00000000
time: 200
time: 200
time: 200
time: 200
Thanks
Arun N
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 //filename: channel_connection.sv `ifndef TEST_ATOMIC_GEN_SV_ `define TEST_ATOMIC_GEN_SV_ `include "vmm.sv" class packet extends vmm_data; rand bit [31:0] vari; rand bit [31:0] vari2; extern function new(); extern virtual function string psdisplay (string prefix = ""); extern virtual function vmm_data allocate (); extern virtual function vmm_data copy (vmm_data to = null); extern virtual function void copy_data (vmm_data to = null); extern virtual function bit compare (vmm_data to, output string diff, input int kind = -1); extern function void post_randomize(); endclass : packet `vmm_channel(packet) `vmm_atomic_gen(packet,"atomic_gen") function packet::new(); super.new(); endfunction function string packet::psdisplay(string prefix); $write( psdisplay, "[%s] vari = 32'h%h; vari2 = 32'h%h\n",prefix, vari, vari2 ); endfunction function vmm_data packet::allocate(); packet i = new(); allocate = i; endfunction function vmm_data packet::copy(vmm_data to); packet cpy; if (to == null) cpy = new(); else if (!$cast(cpy,to)) begin copy = null; return copy; end copy_data(cpy); copy = cpy; endfunction function void packet::copy_data(vmm_data to); packet cpy; super.copy_data(to); if (!$cast(cpy, to)) begin return; end endfunction function bit packet::compare (vmm_data to, output string diff, input int kind); string str; compare = 1; return compare; endfunction function void packet::post_randomize(); super.post_randomize(); endfunction program test_atomic_gen; packet_atomic_gen pkt_gen = new("atomic_gen", "test"); packet pkt; initial begin pkt = new(); pkt_gen.stop_after_n_insts = 4; pkt_gen.randomized_obj.vari.rand_mode(1); //vari to be randomized everytime pkt_gen.randomized_obj.vari2 = 32'h1234_5678; pkt_gen.randomized_obj.vari2.rand_mode(0);//turn-off vari2 randomization with a configured value. $display( "time: %t", $time ); #100; pkt_gen.start_xactor(); end initial begin #200; forever begin $display( "time: %t", $time ); pkt_gen.out_chan.get(pkt); pkt.psdisplay(); end end endprogram:test_atomic_gen `endif //TEST_ATOMIC_GEN_SV_
Output:
time: 0
time: 200
time: 200
time: 200
time: 200
time: 200
