R2R current DAC design
diarmuid
Full Member level 2
Full Member level 2
Dublin, Ireland
Hello,
I need to design a 7bit R2R current DAC.
I am looking at the current mode R2R DAC architecture as a basis. However, I do not
want to convert the output currents to a voltage. I simply want to mirror them out.
This means I wont use an opamp at the output. I am finding this leaves me with the
situation where the reference and output nets at the base of my DAC are not always
at the same voltage, thus messing up my R-2R ratios.
Does anyone have any idea of how to overcome this, good reading material, etc.?
At the end of the day all I want is a DAC whereby my binary weighted currents are mirrored
to elsewhere in the circuit. I want also to avoid the more conventional binary weighted unit
FET approach.
Thanks,
Diarmuid
Use a R2R ladder as NMOS source degeneration - it's achieving constant voltage drop on the ladder and higher output impedance.
//Edit: Now I'm notice that You don't want this solution. Look for this paper
... this leaves me with the situation where the reference and output nets at the base of my DAC
are not always at the same voltage, thus messing up my R-2R ratios.
Does anyone have any idea of how to overcome this ...
You can enforce them to have the same voltage:
