Qustion about Calibre DRC error which is related to the corner of the area of layout
mamadmn
Junior Member level 1
There is an error in Calibre DRC
It says that I should not have any device in the corner of area... Then I think I should use a layer to define the area of layout. But I don't know which layer I can/should use?
Thank you
Usually the corner area is already defined by the DRC rules. Check them!
Hello,
Thank you
I have several errors like DOD.En.2(xxxxx.En.1 for all metals too) which is "enclosure by chip edge >= 0.6" ..... Then I don't know how to define the chip edge or use a special layer.
Thanks
Can you define chip edge by the layer prBoundary.
Or if unsure load layoutXL (if cadence is used) and let it define your chip edge.
