zedrck
Newbie level 2
Opamp Stability
Hi evrybody,
I am currently trying to design a 1GHz low-pass filter with this circuit (cf question.pdf)
I have always worked with circuits running at lower frequencies; so in these
cases, a clean design would have remained to set the cut-off frequency of
the filter with Cs and Cf (like in Butterworth filter config...) and take a marge
of 20dB between the closed loop gain (0dB) and the open loop gain at this
cut-off frequency;
but in this case, it would mean that the opamp regulates the loop with 20dB at 1GHz... and then shows a GBW=10GHz!!!!!
So my question is:
- if my opamp is slower (GBW=3GHz!!!! ;-) ), what´s the matter if Cs = 0 F
and Cf=0 F.... ?
If the cut-off frequency is set by the opamp itself, should I expect any kind of
problem regarding stability, linearity...or whatever?
Thanks in advanced for sharing your minds!
Hi evrybody,
cut-off frequency;
So my question is:
and Cf=0 F.... ?
