chenchangfu
Junior Member level 3
Questions about microstrip antenna array~
I designed a 4X4 microstrip antenna array, from the simulated result the gian is 18db and it is just so-so,but the central frequency has a big offset (from 12.5GHz offset to 11.5GHz and the S11 is also worse). I have attemptted to change the distances between the elements but I still can not get a satisfactory result. Who can tell which resaon can cause this problem? Thanks~
