If two identical digital core circuits, which are, implemented in 0.18um
and 0.13um, respectively. What's the power consumption relation between
the two implementations?
yes, for the same circuit, the improvement is huge,
normally, as process scaling, the design is more and more complex. so we can see that the power of the intel's CPU is more and more high.
by the way, P=a*C*V²*f is only dynamic power
as for other kinds of power, such as leakage power, it maybe higher as the process scaling, because leakage current will increase, under 0.13um, leakage current is a serious problem
Leakage power must be paid more attention in .13 and below tech. In the same design in the same nano level tech, different percent of hvt or svt cell used in the design may result in different power consumption.
