Question regarding to MC33063
shemo
Full Member level 1
1)On this diagram, 24VAC com in into the MC33063, so the MC33063 can take in both AC and DC voltage?
2)RSC1 1.0ohm resitor, I saw 2 of that parallel, is that correct?
3)This circuit shows MC33063 generates 5V output? How do I modify the circuit to generate 12VDC output? Input still 24VAC.
The best source if information is the dstasheet. Read it carefully.
AC:
There is no ac at your MC33063 because you used a rectifying diode and a capacitor.
The MC definitely is not able to handle AC.
Hope this helps
Klaus
