[SOLVED] Question regarding system verilog
srish
Newbie level 6
how to create and write a radom variable in that particular created file?
i use file which is integer type
then file=$fopen(path where i want file to be created)
then $fwrite(file , random variable)
then $fclose(file)
but it is not created and working
plz HELP
oh i find out that the method described above is absolutely right .........no problem with that method of opening and writing the file.
Try to use static integer type for file variable.
