jarred23
Newbie level 2
I'm currently building a circuit that has 4 sets, each set consist of
The datasheet for the 7-segment (CC) I used (ELS-511SURWA) http://www.autcomp.com.br/fichas/everlight/displays/displays/ELS-511SURWA-S530-A2.pdf
This is my understanding, please correct/advise me if I made any mistakes.
CD4511 output drive voltage is 4.5V, meaning each output to the 7 segment is 4.5V. I place 330ohm resistors on each output to limit the current. According to the 7 segment display datasheet, each led inside takes (max) 2.4v, so the current for each led is 6mA. Considering 1 set draws 42mA and I have 4 sets, the total current drawn is 168mA.
My concern is that the current drawn is too high for my liking, and I wish to reduce the current drawn as I'm using 5V voltage regulators to supply voltage to CD4511.
If I replace the 330ohm resistors to 1kohm, will it still work? Doing the maths, each led will draw 2.1mA, and the total current drawn is only 58.8mA. I know the led brightness will go down due to lesser current, but I think the 7 segment display datasheet does not show what is the optimal current required for it.
Thank you guys very much, I really appreciate any inputs on this.
