Question regarding 220VAC to +5VAC converter / regulator
howie
Member level 2
Philippines
I am searching for a 220VAC to +5VDC converter / regulator chipset.
Can someone suggest of other chip that provides the the given conversion. I've seen one from MAXIM (MAX610, 611, 612), it is a chipset that directly converts 110/220VAC to a regulated +5VDC (or even variable 0 to 17VDC) but I still need other options.
Can someone help me regarding this. I will also appreciate other opinions on how to directly convert 220VAc to 5VDC or even 12VDC without using a step down transformer.
Thanks.
Raju C
Member level 2
Bangalore
check out the datasheet attached and check this part no also LNK362GN
