samy555
Full Member level 4
- Joined
- May 11, 2010
- Messages
- 207
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,296
- Location
- Palestine
- Activity points
- 2,963
Hi
When I read the page on the link:
https://www.electronics-tutorials.com/amplifiers/negative-feedback.htm
I found this formula for calculating the output power of RF amplifier:
2 * Po = [Vcc - Ve]2 / R
Also found the same formula in the book: ARRL - Experimental Methods in RF Design, where:
Po: the output power
VCC: the battery voltage
Ve: the emitter voltage
R: the load resistance
I think that number 2 came from a conversion of the Vp to rms
My question is: Why [Vcc - Ve]2 and not simply Vc2 ; the ac collector voltage??
Thank you
Thank you
