Hello,
i found a graphical LCD driver chip, NT7538 i.e. ( other LCD controllers have same mode too)
in the datasheet, about "standby mode" is written:
"Standby Mode
Stops the operation of the duty LCD displays system and turns on only the static drive system to reduce current consumption to the minimum level required for static drive. The ON operation of the static drive system indicates that the NT7538 is in standby mode. The internal status in the
standby mode is as follows:
(1) Stops the LCD power supply circuit.
(2) Stops the LCD drive and outputs the VSS level as the segment / common driver output.
However, the static drive system still operates.
(3) Holds the display data and operation mode provided before the start of the standby mode.
(4) The MPU can access the built-in display data RAM."
it says turns on "static drive", what does it mean ?!!!
does it mean in this mode, LCD shows the last data on pixels ?!
it says in standby mode all segment and common drivers output VSS level. i just thought because of capacitive nature of LCD segments, it may holds the last display frame !
in fact i want to find the lowest possible power consumption on the LCD for showing a frame. so want to know what happens in standby mode ...
