patrickian01
Member level 1
- Joined
- May 17, 2013
- Messages
- 35
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,626
So I built oscillators that produce near-triangle waves and I try to transmit them over a short distance of a few meters using several kinds of antennas. I use a half-wave and quarter wave antennas, although most of them are imperfect. I made 5 oscillators from 13MHz - 25MHz and they have an output voltege of about 600mV pk-pk to 1.2V pk-pk. I use an RG6 coax on the half wave antenna and RG58 on quarter wave antennas and the oscillators have an output impedance of around 50-80 ohms, measured by using a potentiometer as a voltage divider. Given all that, I connected the output of the oscillator to the feedpoint of the antenna and the ground of the oscillator to the ground of the antenna. The problem is this, sometimes, the receiver, also half-wave and quarter wave antennas, only get high values for the harmonics and low values for the fundamental frequencies and on different days, fundamental values are higher than harmonic values. Leaving the alligator clips on the output also serve as antennas and sometimes, I get higher values when the alligator clips are connected. The oscilloscope probes also provide higher values than that of antennas. My question is that, is this all normal, I know that RF is really unpredictable and i also considered the possibility that the signals produced travel through the AC mains and enter the scope through another AC outlet, but i tried removing the alligator clips, leaving the connecting wires connected to the oscillator output and the signal level on the receiver side drops down substantially to barely noticeable levels, so i assume that i must have been transmitting for it to behave like that. The system behaves differently on different days but seem to be consistent on same days (all tests done on the same day seem to follow a pattern). Another thing is that as I get farther, the fundamental frequency disappears and only harmonics can be seen. Is it supposed to behave like that? My professor said that RF is really unpredictable so i get interference from anywhere that could have affected my tests during some days that may or may not be present on other days. So, is this at all normal? for it to behave like that?
