Re: question about pcb glue ? possible usage without reflow oven
As I see on their page, this is an epoxy based glue and will not melt under heat. Normally the component floats on the solder during soldering and positions itself (surface tension forces from the molten solder) but if the glue is cured before that this will not happen. I guess this is suitable for manual placement and soldering.
These are one-part thermo-setting epoxy adhesive with curing temperature of 130 deg C for 5 minuts. It should not cure in normal temperature. Re flow or Oven curing preferring
